pro balancer
I am seconds away from tossing this top flight balancer in the trash. I watched more videos then I can count read the instructions 3 times. I can get a prop to balance take it off put it back on t G e exact same way and the dang thing is unbalanced again. Not to mention turning the balancing rid around with a balanced prop still attached shows the prop that was balanced facing one side is unbalanced facing the other side. Same thing if I balance both the prop and hub.
The prop balancing rod seems true but I have noticed the rod with no props on it when spun and stopped by my finger will always twitch to the same side.
