Brian,
I watched the run video and it looks like you are close to running. The temp looks a little high to me. Do you know if the thermocouple is the correct distance in the tail cone? If that looks right I would try to look up the tail cone while running and see if the flame is even all around the diameter of the engine. If you have any blocked injector tubes the flame won't be even.
