There may or may not a difference at the minutely tiny number's you're talking about. I certainly don't have the equipment to measure the friction and compare the two. I do know that the Du Bro can sense a hub that is one little dot of CA from being in balance. Given the leverage that a hub has versus a blade, I'm confident that the Du Bro balancer is capable of getting the blades perfect and the hub very nearly perfect.
