RCU Forums - View Single Post - Base Coat - Clear Coat Question
Old 10-02-2003 | 02:51 PM
LGM Graphix's Avatar
LGM Graphix
My Feedback: (22)
Default RE: Base Coat - Clear Coat Question
true, but your holes should all be drilled before you paint LOL!!!
Like I say, I base with a 2 part primer, that seals the fiberglass completely, or a clear. Then I use the single part because it is so much easier (not to mention cheaper and lighter) to use. then clear it all. If you should need to drill a hole, just wipe the edge with some thick CA after you drill it, it will seal it all.
