RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 03-25-2014 | 06:23 AM
  #1066
MTK
Originally Posted by myckey
Hi Verne,
I'm hoping you can help as I'm just putting together an Integral I acquired and the build instructions give the c of g as 205 mm behind the leading edge of the wing LE at the root, that puts it about 20mm behind the centre of the wing tube. I thought that looked a bit rearward so looked on here, the measurement you are giving (1/8th of an inch behind LE of wing tube) would equate to something like 173mm, quite a difference, I'm assuming you're right (and also that is where I would expect it be) but can Carf be that wrong?
Phil
Phil, Regards to right thrust, it's relatively simple. Just remember the 1/4" differential in 14" equals 1 degree. That is, if you put on a 14" prop and the tips' length difference when measured from the tail post was 1/4", that's 1 degree (close approximation).
