The problem with the spring starters is that they can never be wound tight or it will ruin the spring.
The one spring coil will pull down through two adjacent coils and then part of the coil will rub on the crankshaft.
I've seen this situation ruin the rear seal on some engines
All it takes is for someone to wind it too tight once?
Try a new spring.
