Proper gauge for RX battery charging
I have searched posts on this site, and cannot find a clear answer to this question. I added banana plugs to a servo extension wire to use as a charging wire for a 2000mAh 6.0V RX NiMH battery, using a Triton 2 EQ charger. The wire is only about 12" long, and I want to extend it to a few feet. Based on what I have read, 22 gauge wire will work for this task. Will this be sufficient? I normally charge the battery at 0.2 amps, but I might occasionally need to charge it at up to 2 amps, if I am in a hurry. I also plan to use the Triton to discharge and cycle the battery.
Thanks in advance!
