RCU Forums - View Single Post - pro balancer
Thread: pro balancer
Old 04-01-2014 | 06:54 AM
  #45
AMA 74894's Avatar
AMA 74894
Moderator
Originally Posted by CafeenMan
I don't stop at the flash though. I take off material until the prop is balanced to my liking. I've never heard that you're not supposed to take material from the hub until this thread. If it's common knowledge then it never made its way to me. In fact, until recently, I've never heard of anyone adding weight to a prop to balance it except by adding clear coat. I don't know how I came across it but a couple weeks ago I saw a video on YouTube I believe where a guy was adding tape strips to a prop for an electric to balance. Seemed like a good idea for electric motors but wouldn't work for glow as the fuel would dissolve the tape glue pretty quickly.
actually tape does work reasonably well with non electrics... (I used it in the early 70's even) since the prop is ahead of any fuel (or fuel spray) the tape does actually stay on pretty well.
(although I'd go a tiny bit light on the tape and add a coat of dope to make it permanent.)
it's not a great idea to remove material, but (ONLY my opinion!) unless you're removing big hunks, it shouldn't be an issue.
