Doug,
I will check the current next time I fly and let you know. As far as flight times, I can fly the Advanced sequence, at "graceful" speeds much like your Conquest
and only use 3000 mAH or less, so not putting a dent in the 5000 nAH pack. If i do each maneuver WFO, I am still under the 80% mark, 3600-3700 used.
I think the biggest drain in Advanced is 6 loops total. I think if I choose a sequence w/o these lengthy loops, I could get through Masters OK, time will tell.
I am WAY exceeding the limit of this prop, a 12x8 APC eProp has a max RPM of 12,083. I am still experimenting with different props, and may end up with a glow prop.
