RCU Forums - View Single Post - 12' Laser-cut Telemaster Kit Build
Old 04-03-2014, 05:20 PM
  #110
isf2008
Cowl continued:
The photos in this post show the cowl with the engine installed. I made sure there was lots of room around the engine for cooling. Note that the engine is 1.25" forward of where it would have been with the stand-offs alone. Hopefully this will enable the plane to balance without any ballast. I'll have to cover the plane and install the servos, etc. before trying to balance. I can move the Smart-Fly power controller and batteries around if necessary.
There will probably be a bit of a break before the next post. I have to clean the workshop in preparation for covering. Wings will be first, followed by the fuselage and tail. Lots of work!
ID:	1983885   Click image for larger version
ID:	1983886   Click image for larger version
ID:	1983887   Click image for larger version
ID:	1983888   Click image for larger version
ID:	1983889   Click image for larger version
ID:	1983890   Click image for larger version
ID:	1983891   Click image for larger version
