Spent an hour in the shop and got a little done.
I never found that 1/4 router bit. It went to Balloonia.
If your not familiar with Balloonia, let me explain.
When my daughters were very small one of the books I read to them referenced Balloonia.
Balloonia is where balloons go when a small child lets go of a helium balloon (as all kids will) Kites in strong winds too!
So when anything got lost around my house, it went to Balloonia.
There is a substantial amount of wealth in Balloonia. It is where the IMF gets all that money to loan nations.
I digress.
I cut the excess balsa from the bottom of the wing, trailing edge spar to make room for the aileron shroud.
If you are interested refer to post 71 on how I went about it.
If you look close at first pic you can see to top wing shroud detail.
Then I glued the trailing edge sheeting down.
Kevin
