Originally Posted by
hsukaria
Hi Mark, thanks for the info. Do you think a Fox74 with a Jett tuned muffler is enough power? Is there a way to find out where the CG should be and also the flight control surface travel? Thanks.
The CG is shown on the plans. Here they are again in case you missed them the first time. Set your alierons up for 8-12 degrees low/high rate, elevator about the same and lots of rudder (till it almost touches the elevator halves). That should get you into the ball park. Remember, this is not a 3D airplane, a common mistake is to use WAY too much control throw. Think smooth and graceful.
-Robert
