Phoenix 8 Restoration
I just picked up an old Phoenix 8 classic pattern plane from a local guy. This is my first pattern plane. It looks quite old and looks like somebody was restoring it already by painting most of it with glossy white primer. I need to go completely over it and re-finish the whole thing.
I plan on putting my Fox 74 with a Jett tuned muffler. I intend to put electric retracts also. My concern, however, is that the airframe feels very heavy. I don't know if all those coats of paint and primer are the culprit.
My questions are:
1. Is it worth it to sand/strip the old paint off to reduce weight?
2. I don't have any instructions for setup for this plane. Is there a manual available for this to help me set up the CofG and the control surfaces ranges?
I will try to post pictures in the next few days, but the plane is not in good shape.
My questions are:
Welcome to Classic Pattern! Here is a PDF of the plans and instructions. This forum is a gold mine of folks with the knowledge to help you get your bird back in the air right.[ATTACH]1987231[/IMG][ATTACH]1987232[/IMG]
-Robert
-Robert
Thanks Robert. Any info would be helpful. I am basically an ARF guy with some kit rebuilding experience. But totally new to pattern.
I will try the Citristip, thanks. I may have some in the basement,
My Feedback: (21)
Mark
What David said on stripping. If you lay wax paper over the citri strip, it will keep the solvents working longer as it inhibits evaporation, just keep an eye on it. Use a plastic scraper and scrape away after it softens and wrinkles up. I picked up a P-8 a few months ago too, needs refininshing but overall good shape and aligned very nicely.
Mark
Mark
-Robert
With all due respect, I think that a fine aircraft such as your P-8 deserves a better engine than a Fox .74. There are many good choices available, I recommend that you look at the O.S. .65 AX. That would be a premier choice.
-Robert
-Robert
The CG is shown on the plans. Here they are again in case you missed them the first time. Set your alierons up for 8-12 degrees low/high rate, elevator about the same and lots of rudder (till it almost touches the elevator halves). That should get you into the ball park. Remember, this is not a 3D airplane, a common mistake is to use WAY too much control throw. Think smooth and graceful.
-Robert
-Robert
My Feedback: (21)
I dont think the plans went through the first time Robert as I didn't see it either. Hsukaria, regarding the Fox .74. I have no experience at all with Fox engines; I've used and still use Rossi, O.S., Kraft, Super Tigre, etc. However, I agree 100% with Robert, the O.S .65AX is a great choice for the plane. Even at 8 - 8 1/4 lbs I think it will pull it just fine for you. Mine was set up for fixed gear, haven't decided whether I'll leave it or cut into for the retracts.
Mark
Duh! Disregard Robert, I see it was linked to the text in your post!
Mark
About the electric gear... Several of us classic pattern enthusiast's have discovered that electric nose gear don't do well bolted right behind one of these fire breathing 2 stroke pattern engines. We've had routine nose gear failures, specifically the Eflite electrics but I'm sure other brands are not immune to these vibrations. Don't ask me how I know.
Eric
Eric
Mark
Mark
Eric
Eric
-Robert
