The factory cg setting are also wrong, I had this plane and just wanted to climb, you "need to push the battery all the way forward to the motor mount, you will need to remove the foam that is the way." It has to land fast like a warbird, it's a great fun plane but not for beginers. It would be more of a 4th plane. As for a second plane the visionare can be a second plane on very low rates.
