Originally Posted by
reyemmanuel
It's not worth getting the Tamiya IR receiver system over the Impact IR Receiver system. Impact is essentially of the same design as Tamiya's, except for the base width where the former is a little bit narrower (likely to avoid IP violation). System-wise (IR led emitter, IR receiver housing, receiver base), it is at par with Tamiya.
At 68 USD, with IR emmitter, IR receiver and receiver base, you can't go wrong.
I have both. Impact was 90 AUD inc postage, whilst Tamiya at 99 AUD inc postage. I got the latter instead of another Impact because it was sold near me and at a nice price. If it was 180 AUD, I'd have ordered 2 Impacts.
Extra info:
The Impact Receiver will fit the Clark base by trimming the base down. This way I can fit both Tamiya and Impact.
About the Impact system;
If you mean the IR receiver system. None.
It you mean in the IR gameplay, slightly in a disadvantage as it has better sensitivity than Tamiya's.
If you mean postage, slightly. Slightly expensive on this end, but probably due to insurance cost and customer support.
cheers,
Rey
Does the Impact IR emitter harness have the correct polarity and proper plug to fit J1 on the Clark TK22?
