Originally Posted by
chris1971
Is anybody else having issues with it climbing like crazy under full power? I trim for about half throttle and when I go for a full throttle pass it climbs like crazy! I am going to try a mix with down elevator with throttle unless some downthrust in the motor will work better. what do you guys think?
This will reduce considerably as you pull the CG aft: the thrust line will streamline with the longitudinal vee ( elevator-to-wing incidence ). Initially shims are the way to go.
