Originally Posted by
kochj
SO what do you think...??? does it wreck the looks of the plane?
I actually quite like it - gives it a 1930's "air"! Putting-on the cowl should be a challenge, though. How did you manage it - I see the front piece cut-off...
I had the same problem with a twin on a Cub - had to cut-up the cowl to put it on, then piece it back together with little servo screws...
