RCU Forums - View Single Post - Piper Cub build options
Old 05-11-2014 | 08:12 AM
bikerbc
I think you are going to be happy with your Radio .. Do you have two servos for your ailerons ? If your ailerons are sharing one servo I would use the MG servo . If you have dual servos then I would use matching servos and use the metal geared on your rudder . As far as your engine goes I still would go with one on the upper end of the recommended size .
