RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 05-25-2014 | 08:54 PM
  #1080
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
So 'a ton' of elevator mix doesn't really appear to be that much when looking at the control surface. It was a lot of clicks due to the high res linkage but maybe only a few degrees of throw. I played with the CG and moving it back didn't really change that but it did feel a little nicer. Thrust line appears to be just right. I'm starting to have some better flight segments. I'll triple check things with the meters before making any changes to the wing incidence but it seems like it needs a slight adjustment to be just right. Probably won't happen before the D4 warmup but we'll see.
