RCU Forums - View Single Post - Looking for Ammo Info.
Old 06-02-2014 | 04:34 AM
SrTelemaster150's Avatar
SrTelemaster150
Originally Posted by CLBetten
The method you mention would be the most simple DerFly but I don't think that would leave much material for the threads. I hoped to cut the end cap off and thread the id of the casing. I may have to choose slightly larger and fill with some brass or solder then drill and tap.
I just measured the extractor groove of some '06 brass. The groove is .406", too small for 11mm threads.
If you trim the the case head off just ahead of the groove, that will leave you with about 5/32" of "web" for threads. Not a lot.
If you fill the extractor grove W/brass, then drill out the primer pocket & tap, that would give you a solid 1/4" or more of threads. Probably enough if a jamb nut is employed.
The 30/30 is only .422", 10.72mm ahead of the rim so that won't work.
