RCU Forums - View Single Post - Tactic TS40 Servo
Old 06-12-2014 | 06:58 AM
Bax
If the feedback pot in the servo won't move when you adjust it, then it should work. Please be advised that you'd void any warranty.
Also, you can try adjusting the servo arm on its shaft. If you can get it very close, but not centered, try replacing it 180-degrees from where it is now. The odd number of splines on the output shaft should allow you to get so close that any deviation is negligible.
