RCU Forums - View Single Post - Macchi kits
Thread: Macchi kits
Old 06-15-2014 | 07:48 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
I'm just finishing up on Airraptor's Macchi kit now. I documented a few steps of the construction in order to demonstrate the level of fabrication the end user will receive. I also need to publish specs.
wingspan: 62"
length: 54"
wing area: 520 sq in
weight: 6 to 7lb depending on equipment.
The first pictures are of the wing construction. 1 lb white foam with 1/16 sheeting. The spars are 1/8x1/4 balsa that have a glass box and CF caps. Wheel wells are pre done as are the retract mounts. The mounts are a box that ties into the spar. The end user needs only to fabricate a mounting plate to fit the particular retract and then epoxy that plate into the box. The tail section is pre sanded balsa that gets glass bagged.
ID:	2005501   Click image for larger version
ID:	2005502   Click image for larger version
ID:	2005503   Click image for larger version
