RCU Forums - View Single Post - Spinner
Thread: Spinner
Old 06-16-2014 | 03:10 PM
apereira's Avatar
apereira
Hello Scott,
No, that used to be the one for everything, it's the first version, then they changed for the electric turbo backplate, but the one I show (turbo) is one of the newest and it is strong enough for the YS , if you have experience with the YS and the correct starting procedure which I am sure you and Ryan are, it should be ok. On the other hand I cannot recommend this setup to people who does not have a lot of experience.
BTW, the bolt has to be filled down to a conical shape to fit the spinner. I can also recommend you to check the YS prop nut form Hobby Net is 10grs!
Best regards
Alejandro
