RCU Forums - View Single Post - Cessna Skymaster 337
Old 06-17-2014 | 12:41 PM
iFLYrc_Vic
Default Cessna Skymaster 337
I am building a Cessna Skymaster 337 model made by Seagull. This plane has two in-line motors, one forward (tractor) and one rear (pusher). It has the following specs:
  • Wing Span: 76.8 in
  • Wing area: 806 sq in
  • flying weight 10-11 lb
I will be converting this model to electric and using two Scorpion S-3032-8 motors. Using the Scorpion Calculator, these motors will generate 2081 gf static thrust with an APC 10 x 7E prop (635 Watts IN). My questions are:
1. Should I double these numbers to calculate the total thrust generated by the two in-line motors OR is there some thumb rule for calculating the total thrust for in-line configured motors?
2. How do I calculate the power generated (watts) for the in-line configuration?
Vic
