Polk tiger moth 36" span
Just got my moth from polk for $70 its nice perfect covering well built can be electric
speed 400 or small glo 10 to 15 is overkill 06 to 09 is more like it ,Instructions very
sparse a newbie would be totally lost. All hardware is good I called polk to get the
cg (3 1/2" back of leading edge top wing) If you know what your doing you really
do not need them John Gill up at polk is making new instructions I did buy their
sub micro servos for the wing (2) perfect fit slotted for them they are only 9mm
thick these are the thinnest I have seen the the wire extensions are already in the wings cut solder and hook
up saves buying a Y harness will power with my norvel 061 or paw 09 will work
that out , Tank comes with it 2oz but you suppy the engine mount yes formed plastic
cowl
Summing up a very very nice little moth
