 Polk tiger moth 36" span >
Old 10-05-2003 | 07:49 PM
AMB
Default Polk tiger moth 36" span
Just got my moth from polk for $70 its nice perfect covering well built can be electric
speed 400 or small glo 10 to 15 is overkill 06 to 09 is more like it ,Instructions very
sparse a newbie would be totally lost. All hardware is good I called polk to get the
cg (3 1/2" back of leading edge top wing) If you know what your doing you really
do not need them John Gill up at polk is making new instructions I did buy their
sub micro servos for the wing (2) perfect fit slotted for them they are only 9mm
thick these are the thinnest I have seen the the wire extensions are already in the wings cut solder and hook
up saves buying a Y harness will power with my norvel 061 or paw 09 will work
that out , Tank comes with it 2oz but you suppy the engine mount yes formed plastic
cowl
Summing up a very very nice little moth
Old 10-05-2003 | 08:03 PM
AMB
Default RE: Polk tiger moth 36" span
Forget the only real challenge is the wing the wing cabanes need a diagonal added
the ones between the the top wing and the fus. are 6pcs of formed wire about 1/16
need to be wire wrapped and ca glued may just make 2 N shaped pcs of 1/16 ply
or ALuminum sheet
