RCU Forums - View Single Post - phenoix 2000 issue with assembly rear control rods
Old 06-23-2014 | 05:07 AM
jester_s1
Moderator
Would turning the servos around 180 degrees fix the problem? You will probably notice that the output isn't in the middle of the case, so it will make roughly a 1/2 inch difference to turn it around. It's possible that the factory worker who built your plane put them in backwards, and it's also possible that the wrong pushrods were set with your kit. Both are easy solutions.
