RCU Forums - View Single Post - 9503 set up for elevator and second elev. servo slave. Trim will only actuate elev.
Old 06-23-2014 | 07:08 PM
AWorrest
Use the dual/mate feature in the System Wing Type menu to tie two control surfaces together and not a program mix. The dual/mate is a simplified program mix made especially for this purpose. In ACRO, when you use a program mix for something like dual elevators, ailerons, etc., only the master channel’s rate and expo are transferred to the slave channel. The trim is not. (The throttle is an exception to this.)
In the GLID and HELI configuration you can mate two control surfaces and have trim carried over to the slave, if the master channel has a + suffix. Neither of these configurations has a dual/mate option.
When you pick a Wing or V-tail type in the Wing TYPE menu, it’s the same as using the dual/mate on the bottom of the menu. Not all possibilities are listed, such as dual elevators, so you must set them up yourself.
To use the dual/mate, you must first make available an unused slave channel. This is done by inhibiting the channel output(s) you wish for mating in the DeviceSEL, except for AUX4. AUX4 can’t be used for dual/mate.
When the dual/mate rather than a program mix is used to couple two surfaces, special operational configurations will are possible, such as FLPR, RUDV, AILV, and FROL.
If you have dual flaps, why not set up dual flaps in the Wing TYPE menu if you have a spare channel? It would allow you to set the subtrims independently.
Allan
