I've seen plans for building tables on RCU that went from fairly simple to really extra fancy. The one common thread with all though is that the building surface is supported by a grid of 2x4s that you can slip thin wedges between to adjust the building surface to be level. If you build your table so you can get to the support structure from the bottom, it will let you fix any changes that happen over the seasons.
