RCU Forums - View Single Post - Dle 120 please help!!!!!
Old 07-05-2014 | 05:38 AM
acerc's Avatar
acerc
Originally Posted by speedracerntrixie
It takes a bit of a keen ear but by moving the prop back and forth against compression you will be able to hear the reeds clicking. I personally doubt it's an issue with the reeds. My first twin was an old 3W 70. I bought it new but from a friend. Not knowing any better I set out trying to fire it up after getting it mounted in the airplane. On choke it would pop as normal but off the choke it would fire and quit very quickly. Just as I was giving up on it my buddy whom I bought the engine from called to let me know he had removed the reed block and had forgotten about it. So even without reeds you can get the engine to at least fire.
Speed, you know as well as I do that the reeds control the intake. And the reason for the pop and fire without running is the reeds are not closing thus allowing the majority of the fuel being taken in to come right back out. In my opinion your statement is a bit misleading.
