RCU Forums - View Single Post - DLE-35 Walbro carb replacement?
Old 07-05-2014 | 03:02 PM
ayrobotech
Question DLE-35 Walbro carb replacement?
I've had it with DLE engines. Anyways I have a DLE-35 on a P47 and I have yet to have it run properly. I had it running after about 50 flips of the prop the first time and it ran for a while and then wouldn't run right and would run only if you started it on full throttle. I took apart the carb and cleaned it out good with carb cleaner and put it all back together and all night long I have tried to start this engine and the best it did was to pop once under choke. I cannot get this engine to run. I have spark and the spark plug is wet, yet, it will not run. Its intensely frustrating since this is a brand new engine.
This is the second DLE that I've owned with intense carb issues. The first was a DLE30. Does anyone know a direct walbro replacement for the DLE35? I have found a few at hobbyocean.com that are made for a 20cc-30.5cc and a few for 40 to 55cc, but nothing that would cover a 35 CC.
Thank you
David
