Try this first, pump out the gas that is in the tank if you can't pump the gas out your fuel pick up came off and thats why it stop running after 5 min. The gas is now below brass tubing going into the tank. This happened to my Comp arf 300sx with DA100L. cheek for correct size fuel line for the pick up in the tank. Hope this helps.
Dan S
