RCU Forums - View Single Post - Dle 120 please help!!!!!
Old 07-08-2014 | 09:43 AM
  #65
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by pbilt024
Thanks, a more accurate timing check (showed approx. 33 degrees)is in order as well as a reed block mod to see if either helps. Also pulled the jugs off to make sure there had been no piston scoring and everything was as smooth and shiny as it was supposed to be.
Yes 33 degrees is a bit much. Try setting to 28. That far advanced may have been the cause of the first flame out being that engines will run hotter with that much advance. Getting hot can also warp things and make them leak. I would also still advise you to make sure the hub key is intact and the hub did not slip on the crank.
