RCU Forums - View Single Post - Question about Buddy BoxThrottle programming for a P70
Old 07-11-2014 | 12:05 PM
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default Question about Buddy BoxThrottle programming for a P70
Master Tx is a Futaba 12Z that is properly programmed for the P70 throttle. Failsafe works properly using two channels (THR and AUX).
Im setting up a Futaba 9C to be used as the Buddy Box and want to know where to set the 9C endpoints for the THR. The base endpoint settings are at 75 and 75 for Full and Idle matching what is in the 12Z.
Using the GSU R/C check menu with the 12Z at full THR Stick Pulse is 1237 and 100% idle THR Stick Pulse is 1765 and 26%
When I turn over to the 9C at full THR Stick Pulse is 1246 and 100% idle THR Stick Pulse is 1755 and 26.6%
My understanding of the programming is that the 9C settings must be within the range of the 12Z settings. It looks like my Idle setting and Full setting are within the range of the 12Z Is this correct??
Pete
