I'm glad you found it. I'd still worry about vibration causing that issue though. Your receiver definitely shouldn't cause twitching like that, even with heavy vibration. I'd suspect the servo pots more than anything else. But it's entirely possible that your prop issue has alerted you to a problem that was preexisting, and now you have a chance to fix it before it costs you a plane.
