Between a few battery failures while flying and switch failures on the ground, I want to prevent anything else. I run 2 4200mHz NiCads, 2 switches on separate receivers and had 1/2 an airplane; I want power redundancy.
It may be bad timing/luck...but I don't want to loose any aircraft this way.
