Does anyone own a Clark TK35 board?
Hey all,
Is there someone besides myself that happens to own a TK35 board? If so, can I ask you the following questions?
1. How do you have your movement, traverse, elevation, fire controls setup on your radio?
2. What mechanism are you using for turret traverse? I've hacked 3 servos for 360 degree rotation some with and some w/o circuitry none of which seem to work properly. I'm not sure what traverse mechanism is supposed to be used given these boards were mean for 1/35th scale.
3. Did you use a servo for elevation, if so, do you have to move the stick (depending on your configuration) 3/4 in some direction then move it again to make the gun elevate? Very complicated IMO and I lack the dexterity to do it half the time and end up firing the gun when I only meant to elevate it.
I'm not sure if the TK22 is this frustrating or not, but I'm having a real hard time with the TK35 at the moment in getting it in the ballpark of functioning like a Tamiya setup.
Dave
