RCU Forums - View Single Post - Jetcat P160SX Question
Old 07-21-2014 | 04:04 AM
Greg Wright's Avatar
Greg Wright
It sounds as if you don't have the solenoid plugged into the correct port on the ECU. I have done this by mistake before myself. It is very easy to do on the Jet Cat ECU's. With it being a SX version you should see a burner test function on the GSU. That is how you test the Kero plug solenoid.
A picture is worth a thousand words!!!!!!!!!
