Dave, Gary, Greg and Jetcat,
Thank You all very much for your assistance. My turbine is a P160SX, V 6.0. I have checked the connections at the ECU and they are all fine. I have checked the GSU upon powering up and it states the same and that it is Kerosene Start. I knew that the plumbing was correct splitting the kero at the pump discharge to both solenoids. Having checked and rechecked I came to the conclusion that It must be "Operator Error". I had been activating the "Pump Start Up Voltage" run button, expecting to see flow at the start up line. I needed to be activating the "Burner Test Valve" to verify flow at the start up line. Everything looks good and I am certain that it will start up flawlessly. I feel a bit stupid but hopefully this will help out someone else in the future.
As always, thx to Jetcat for their outstanding customer support !!!
Slightly embarrassed,
Bill
