RCU Forums - View Single Post - phenoix 2000 issue with assembly rear control rods
Old 07-22-2014 | 07:42 AM
AMA 74894's Avatar
AMA 74894
Moderator
it should be a very simple matter (although absolutely shame on hobby king) to replace the pushrods and Clevises (it's the crappy clevises, NOT hinges that are bad on that airframe.)
you may be able to use the existing pushrods by simply turning the servos 180 degrees (putting the servo arm closer to the rear of the aircraft.)
looks like a 10X6 folding prop is what they recommend.
there are a good number of you tube videos for this airplane, like most of HK's stuff this airplane needs a little work to make it flyable.
https://www.google.com/search?q=hobb...x-a&channel=sb
good luck and keep us posted
