RCU Forums - View Single Post - how to attach a magnet to a Webra Prop Hub?
Old 08-02-2014 | 04:06 PM
captinjohn
Cut that sleeve to the correct width so as to have enough material to drill for the magnet. The hole for the magnet can be a tad larger & use JB Weld to hold the magnet in place. The sleeve would need to have no steel in it. Have some person that has a lathe make a timing ring out of aluminum. Real easy to do. Good Luck.... Capt,n
