Does anything need to be tweaked on the newer versions that were purchased post "recall" ? (specifically for me s/n 180760 and above)
In the limits menu, I assume the Barom Auto Tune should be set for both Idle&Ramp-Set ?
Both IdleThr & FullThr Response are default to Fast - is that ok or do both need to be set to Normal ?
Any other settings need to be adjusted?
Getting ready to run mine for the first time & want it set right from the start. Don't need any additional surprises on a maiden flight.
Thanks...Scott
