RCU Forums - View Single Post - S-Bus in pattern biplane?
Old 08-15-2014 | 10:23 PM
Derek.Koopowitz
Originally Posted by OhD
Has anyone rigged a biplane with S-Bus aileron servos? If so, how did you set it up? Do you use four channels to set sub trims and throws in the transmitter or program the servos or both? Is there a better way?
Jim O
Jim,
I'm planning on using SBUS in my biplane as well... rather than using 4 channels for ailerons that Alejandro is using, I plan to use 2 channels and I will program the centering directly on the servos and also the max throws so that they hopefully will all match. Since my rudder servo and 2 stab servos all sit in the rear of the plane, I am also only running 1 SBUS hub cable to the front versus 3 separate servo extension cables. Saves weight and clutter.
