Originally Posted by
Derek.Koopowitz
Jim,
I'm planning on using SBUS in my biplane as well... rather than using 4 channels for ailerons that Alejandro is using, I plan to use 2 channels and I will program the centering directly on the servos and also the max throws so that they hopefully will all match. Since my rudder servo and 2 stab servos all sit in the rear of the plane, I am also only running 1 SBUS hub cable to the front versus 3 separate servo extension cables. Saves weight and clutter.
Derek,
It might not matter, but you will find that you can set the sub trim and maybe the travel, more accurately in the transmitter, (one part in 2048). It has been awhile but I remember that the servo could not be programmed that accurately (.25 degrees?). Therefore the four channel approach might be better.
Jim O
