Originally Posted by
skyraider71
Sorry guys, been away for a while, got sucked in to FB and youtube. I'm a glow engine
enthusiast, that's what I know best. I'm currently flying my 2X4 with a throttled Norvel .061
The 2X4 is OK but it has some short comings I'd like to have a better, more efficient glider.
I like glow because because I already have it, going electric means lots of stuff to buy.Besides,
I wasn't sure a brushless set-up would fit in either plane.
Though this has been discontinued there are still kits around its a gentle lady converted for electric. In fact I think it comes with an old brushed motor which means lots of room for a brushless replacement.
http://www.carlgoldbergproducts.com/.../gbga0040.html The electrics are not hard to figure out most motor manufacturers give you the prop sizes and battery configurations. The extra weight does not effect the performance as much as you would think. A little in calm air but the little extra weight gives better penetration in brisker winds.
This will out perform any of the Goldberg Lady’s in all aspects and is much better built. It’s available still today. Mine is at least 10 years old and still wins many club glider competitions. It has rudder, elevator and pop up spoilers as well as the electric motor. It’s only 85 dollars and is one of the easiest gliders I have ever built. At the bottom of the web page it gives some tested combinations motor, esc and battery combos.
http://www.djaerotech.com/dj_product/chrysalis2m-e.html
Being able to fly and restart the motor when low you will get several climbs to altitude with one charge something you cannot do with your nitro motor. Another saving grace with electrics is the ability to keep the model out of the rough by being able to throttle up the motor to get you back to the field or make a go around if you need to. This can save a ton of repair work and help keep the model light and straight for many years.
Dennis
