Originally Posted by
Vettster
David.. What did you set the START/MIN TEMP at?
Also Im a bit confused by the way you posted some values. For example... Start power at ignition 089/069 so which is it? I guess Im asking what the exact values you are using as there seems to be a lot of leeway.
I believe he has both values listed for both engines with the first number being the value for the 1300 and the second value for the 600. (i.e. 089/069)
