Originally Posted by
Vettster
Sorry David.... One more missing parameter. Under the RUN menu... What is your STOP SPEED RPM set to?
Sorry for troubling you..
EDIT.. Since my engine has an idle speed of 50,000 Ive set it to 40,000 John does this sound ok? Engine is now on the test bench and about to be run for the first time with the xicoy FADEC
yes I would give it a try with the figures you currently have. The engine may start first time, but you may have to tweak them. You should be ready to stop the start by raising the trim if the engine fails to gain speed and the rpm slows and it gets hot. Make sure if you are using Futaba to reverse the throttle channel. Also make sure you correctly go through the learning Tx procedure.
i will be very interested to hear your results.
John
