kill switch problem
i have a dle 30cc in a ecom dvii with a opto killswitch. First fite every thing is fine but on the second flight the engine starts then quits and the opto kill swtch blinks end the engine will not run. Ihave replaced the ignition module and the problem was not corrected help ihave a futaba 2.4 radio set up switch on channel 6 with end points at limit.
