RCU Forums - View Single Post - Dynam Smart Nose Gear
Old 09-04-2014 | 06:57 AM
rctrost
Default Thanks
Originally Posted by stu48
Try a piece of brass or aluminum tubing as a bushing for the 1/8" wire. You might have to slightly enlarge the bracket holes. It wouldn't be very much.
Sounds like that would work if there is still enough meat left in the carrier for the set screw. Since the diameter was so close I used 1/8" music wire without shim which seems to be doing the trick. I also cut a plywood plate to fit inside the fuse' over the nose wheel bearing and ran screws from the corners of the bearing plate into the ply. Made sort of a sandwich which should help with the plate tearing out. Either that or it will break out the entire bottom LOL. The plane itself has become one of my favorites.
