I think this is the picture you are looking for
Just solder them to the same leads on the upper hull connector. If you really want to you could tap into pins 6 and 7 on the lower 8p connector coming out of the motherboard so you dont have to have a disconnect for the upper hull when you remove it. Tapping it from the lower hull is probably the better idea.
